Author Topic: locking wheel bolt  (Read 1833 times)
Offline gtiaps
locking wheel bolt
« on: 11 March 2016, 13:29 »
Hi all
Same as the spacers post this has probably been done endless times but again easier to ask fresh as possibly more than myself looking to do this..
Anyways are these the correct locking wheel bolt to suit 15mm rear and 10mm front spacers secured by using longer wheel nuts which are supplied with the spacers these are just the locking bolts..
https://www.performancealloys.com/locking-wheel-nuts-bolts-details.aspx?ID=162
Thanks in advance Neil
2010 Candy White Scirocco 2.0 TDI
2016 Carbon Grey Gti 2.0 Fully Loaded
COLLECTED 29/4/2016 and well pleased with the GTI😆😆
Offline vidman2
Re: locking wheel bolt
« Reply #1 on: 11 March 2016, 16:10 »
Simplest is to measure the thread length on the standard bolts and add the 15mm to get the length you now need, 1 or 2mm under should be OK
2015 R DSG. Limestone Grey, DCC, Winter Pack, Tech Pack, Reversing Camera    plus   2013 Mk7 GTi DSG - Performance, Navigation, Winter Pack, DCC, Park Assist,
Offline wigit
« Reply #2 on: 11 March 2016, 16:34 »
You need radius bolts for OEM wheels, I have a set of these on my aftermarket set and fine but VW cover cap is unlikely to fit as the head radius to help
