Author Topic: Severe juddering after gearbox and clutch change  (Read 2513 times)
Offline ImIMK3
« on: 09 March 2016, 14:20 »
Hello all. I recently had the gearbox and clutch changed on my MK4 and before the car went in there was no juddering at all. Took it to the garage they advised me the gearbox was naffed which I thought was messed up and the clutch release bearing needed changing. So I got a 2nd hand gearbox in good working order along with a new clutch from euro car parts. Got the parts installed drove the car home and there was severe juddering as well as the steering not aligning properly when turning meaning that turning left is fine but turning right is awful. Any thoughts?
Offline MoMartin
Re: Severe juddering after gearbox and clutch change
« Reply #1 on: 09 March 2016, 17:17 »
Take it straight back to the garage mate
A problem that large should be corrected free of charge (unless the gearbox was knackered when you got it, in which case they could blame that on you)
Offline ImIMK3
« Reply #2 on: 13 March 2016, 15:11 »
I don't think it's the gear box because it changes gears perfectly. When you drive the vehicle the steering is really wayward. Turning left is fine but turning right is a rightmare
Offline Nino
  • Insta - F6UGA
« Reply #3 on: 13 March 2016, 16:03 »
They may not of installed dogbone mount correctly?
Current - MK6 GTi Edition 35 - Candy White - 3 door.
Offline ImIMK3
« Reply #4 on: 15 March 2016, 12:10 »
I will have a look at the dog bone mount. Would that be affecting the steering?
Offline Bellend
« Reply #5 on: 16 March 2016, 07:58 »
What brand of clutch?
Where all my moneys went.
