Golf mk4
Wazzzer
Idling issue
Topic: Idling issue (Read 3395 times)
Archieback
Just got here
Idling issue
08 March 2016, 21:15 »
Hi. My 1.8 T doesn't idle, it just drops down to 500 rpm when i think the anti stall kicks in and flicks the revs up, for them to drop off again. Only had the car a few days and only done one trip of 60 miles. Any ideas? Thanks
barrym381
Forum addict
Re: Idling issue
08 March 2016, 21:24 »
probably best getting it scanned to see what comes up
ImIMK3
Re: Idling issue
15 March 2016, 12:20 »
Check the MAF sensor on the car. Disconnect it and see how it idles. Otherwise run a diagnostic on to get the fault codes
MR FAKELAFF
Re: Idling issue
11 July 2017, 21:20 »
Have had your dodgey scanned or VAGGED I like to say
. Mine sits a bit high on cold start for few seconds then it drops to normal. I thought of couple things like mapped ecu reading the command from mapp etc or secondary air pump has given up / coz there dead reliable on 1,8T
As stated in the thread vag com is best option
Wazzzer
Moderator
10k hero
Golf GTI 1.8T AGU
Re: Idling issue
12 July 2017, 21:17 »
sounds like an air leak. Check all of the breather hoses over including the ones under the inlet manifold
1999 1.8T: R-Tech remap - 225bhp/256lb/ft : K03s : THS FMIC : THS PCR pipe : 2.5" stainless exhaust : THS FR3 Engine mounts : G60/VR6 clutch : Calibra Yellow injectors : VR6 MAF : Devils Own WMI : Forge 007p : Carbonio CAI : Leon Cupra R Brembos : FK AK Street coilovers : Votex skirts : Anniversary front : click --->
http://www.golfgtiforum.co.uk/index.php?topic=92175
Golf mk4
Wazzzer
Idling issue
