Author Topic: code fault  (Read 2916 times)
Offline crazydog
code fault
« on: 05 March 2016, 16:29 »
hi guys, engine management light came on,still came on next day,so ran scanner through and came up with 00532 which relates to supply voltage b+ also 18010 which relates to power supply b+ terminal 30 low voltage. any ideas and which is terminal 30 cheers all ideas appreciated   crazy dog
Offline golfhappy
Re: code fault
« Reply #1 on: 05 March 2016, 20:04 »
Have you disconnected the battery at some point. On searching also could mean power supply to a component.
Audi S1 gone, awaiting 1.5tsi r-line, pan roof, led lights front and rear, active dash, 18" jurva alloys and a dealer fitted Oettinger roof spoiler in tornado red.
Offline golfhappy
Re: code fault
« Reply #2 on: 05 March 2016, 20:14 »
See if this translation from a German site helps.
18010     P1602
  This error code is "Manufacturer Specific" (for each car maker a different description and meaning). The following description / symptoms / causes / solutions specific to VAG cars.
nl   Supply voltage terminal 30: voltage too low
du   Power supply, Klemme 30     Spannung zu klein
and   Power Supply Terminal 30     Voltage Too Low
Additional information on the error codes.
Note : The following information is not coming from the VAG group, or from numerous other sources. Complete and error can not be guaranteed. Keep critical thinking.
Possible symptoms:
Loss of function (in a place not to predict)
Possible causes:
The cables from the battery, there have been off (indeed, you get such an error)
The battery has a low voltage
The alternator is bad
Possible solutions:
Check the cables from the battery
Check (measuring blocks) / replace battery
Check / replace the alternator
Offline crazydog
Re: code fault
« Reply #3 on: 06 March 2016, 14:38 »
thanks, battery new last sept.alt.giving 14v+ at meter connections tight and clean.disconnecting battery for an hour or so start up light goes out comes back on three/four days later,ican do this again same result,car runs perfect can't detect any running faults.by the way its gti 18t mk4 chipped 3 not recent been done for acouple of years no probs. thanks for all ideas will check.   crazy horse.
Offline crazydog
Re: code fault
« Reply #4 on: 06 March 2016, 14:48 »
sorry meant to ask as well where is terminal 30. thanks.
Offline golfhappy
Re: code fault
« Reply #5 on: 06 March 2016, 16:41 »
http://wiki.ross-tech.com/wiki/index.php/18010/P1602/005634
Look at the note at the bottom of the page!
Offline crazydog
Re: code fault
« Reply #6 on: 08 March 2016, 15:58 »
THANKS ALL SORTED
