Author Topic: Mk3.5 Golf Convertible  (Read 4006 times)
Offline nealy1572
« on: 03 March 2016, 20:22 »
Hi
I have a mk3.5 2.0 AWG  golf convertible with some running issues  as below can any body help im at my wits end
1 - Secondary air injection pump system. Short to ground
2- Evap purge valve N80.Short to ground
3- Mass air flow. Signal to low
     I have changed air mass sensor and still
     the same
Thanks for help in advance
Offline gasketface
Re: Mk3.5 Golf Convertible
« Reply #1 on: 04 March 2016, 17:57 »
do you mean agg engine ?
What problems are you having ?.
Offline itavaltalainen
« Reply #2 on: 04 March 2016, 19:08 »
The mk3.5 had a different engine (AWG with Bosch Motronic).
Can you post the full scan protocol (includes ECU part numbers, fault code numbers, etc, etc)
Offline gasketface
« Reply #3 on: 04 March 2016, 20:50 »
I have 2 3.5's,one has an ABA engine,the other earlier one has the AGG lump.
I can't find any link to an AWG unit so was it non UK unit ?
« Reply #4 on: 04 March 2016, 20:54 »
ABA was a US engine, but wouldn't be surprised if it found its way to some UK cars.
AWG was on late 3.5, but probably only a few ever made it to UK but not a case of it wasn't sold it here but mere coincidence. It is relatively rare.
Offline gasketface
« Reply #5 on: 04 March 2016, 20:58 »
It's o.k i found it on ETKA,never seen one though.
Yeah the ABA was fitted to Golfs etc in US instead of AGG unit.Much more tuneable than the AGG though.
I'm off to look for more info on this AWG now  :laugh:
Offline nealy1572
« Reply #6 on: 05 March 2016, 15:13 »
Just read codes as below
1 - 17859 -Secondary Air injection system short to ground: P1451
2 - 17833 - Evap Purge Valve (N80) Short to Ground P1425
3 - 16486 - Mass Aor Flow sensor (G70) Signal to Low P0102
