Author Topic: Mk4 golf 4motion 1.8t  (Read 4859 times)
Offline markgti1.8t
« on: 16 February 2016, 23:14 »
Hi going to be getting a 4motion to convert to 1.8t is there any suggestions on doing so I know I will need s3 box loom and Ecu is there any other things I would need thanks
And can this be done with Agu engine
AGU fk coilovers Powerflex top mounts full 3inch decat turbo back viper induction kit fmic vr6 clutch g60 flywheel catch can 007 forge dv Power flex wishbone bushes  Power flex dog mount under brace JOM  ADJUSTABLE Drop Links Walbro 255lph INLINE Fuel Pump wmi now fitted WAITING TO FIT VR6 MAF SAAB RED TOP INJECTORS STILL TO BUY K300 TURBO  CON RODS LSD
Offline barrym381
Re: Mk4 golf 4motion 1.8t
« Reply #1 on: 16 February 2016, 23:19 »
just buy mine its all done  :whistle:
Offline markgti1.8t
« Reply #2 on: 16 February 2016, 23:30 »
Much you looking for yours
Offline barrym381
« Reply #3 on: 16 February 2016, 23:33 »
god knows if your interested I can send you the spec list but your in Glasgow so welcome to view anytime you want  :smiley:
Offline markgti1.8t
« Reply #4 on: 16 February 2016, 23:35 »
Pm me your Facebook
Offline barrym381
« Reply #5 on: 16 February 2016, 23:37 »
Pm me your Facebook
don't have facebook mate  :smiley:
Make: VW
 Model: GOLF
 Colour: AUDI SPRINT BLUE
 Year: 1998
 Engine size: 1.8T
 Fuel type: PETROL
 Transmission: 6SPEED MANUAL
 Mileage: 98k
 MOT: MAY2016
 vw golf gti turbo which has all the modifications which are listed below,the car is a complete one off all the mods the 4wd has all been done professionally and can be supplied with photo's of the conversion the car has just covered over 98,000 miles but is in daily use the engine has covered just over 56,000 miles since being built with forged items the floor was from a 4 motion of which both floor pans were carefully unpicked and spot welds drilled so they could be re-welded to the original factory spec,the subframe and diff are from a r32 and it is using kw variant 3 suspension. It has the transfer box from a audi tt also using the 6 speed box from a audi tt
 TT 225 9.0:1 Compression piston’s
 Audi TT225 Manifold
 Audi TT225 K04 Turbo , brackets and oil feed pipes
 Audi TT225 Fuel Pump
 Audi TT225 Injectors
 Fly by wire Inlet Plenum (Modified for throttle cable)
 4 Bar Fuel Pressure regulator
 Helix Organic Clutch
 New Big End & Main Bearings
 New Oil Pump
 New Head Gasket
 New Cam Belt Kit
 New Metal Bade Water Pump
 FORGE 008 Dump Valve
 Pipercross TT225 Air Filter
 VR6 MAF Housing
 SFS Silicone Turbo Intake Pipe
 CUSTOM REMAP BY R-TECH
 Modifications done when converted to four wheel drive:
 Boot floor out of 4 motion golf
 Rear Subframe, diff and suspension from R32
 Audi TT225 6 Speed Gearbox and Transfer box
 Audi TT225 Flywheel and ECS Tuning Kevlar Stage 3 Clutch – good for 400whp
 Golf 4 motion Propshaft and front drive shafts
 4 Motion Controller made by Dutch Build
 Customs Stainless Exhaust less than 3month old
 KW Variant 3 Audi S3 Coilover Kit (fully height, bump and rebound adjustable)
 Vibra Technics Road engine Mounts
 Custom Front Mount Intercooler
 Custom Hard 2.5” Intercooler Piping painted black
 Forge Intake pipe with Dump Valve Relocator
 Goodridge Braided Brake Hoses
 Forge Rear Camber Rod’s
 Chassis Modifications:
 19” R32 Style Alloy Wheels
 Porsche 996 turbo front callipers
 356 x 32 front discs 308x22mm ECS big discs kit for rear
 25th Anniversary rear callipers
 Body Modifications:
 Genuine R32 Rear Spoiler
 Genuine R32 Side Skirt’s
 R7A Design’s Rear Valance modified to have twin round pipes
 One off front bumper, modified to use original grille, and late type plastic mesh
 Full re-spray in Sprint Blue
 there is a pair of genuine r32 bumpers with car too just need painted and fitted
« Last Edit: 16 February 2016, 23:39 by barrym381 »
Offline markgti1.8t
« Reply #6 on: 16 February 2016, 23:42 »
Any pics
Offline barrym381
« Reply #7 on: 16 February 2016, 23:44 »
