Author Topic: These MK7 R's... cain from day 1 or run in....?  (Read 10131 times)
Offline Mrparkuk
Re: These MK7 R's... cain from day 1 or run in....?
« Reply #10 on: 14 February 2016, 19:08 »
 :sad:
I asked my stealer the same question. He said they are pre run in in the factory. So get her up to temp and rag it!
I concur
Current-Jan 2017 M140i, auto. Mineral Grey. ☠😈
Gone-mk7 golf Gti PP, Carbon Grey, 2015 specification, 5dr.
Offline remlapeel
« Reply #11 on: 14 February 2016, 20:08 »
Get the oil temp up then smash it!
2015 MK7 Golf R 3 door, DSG, lapiz blue, 19" wheels, winter pack, keyless entry, dynaudio and high beam assist.
Offline Bungleaio
« Reply #12 on: 14 February 2016, 21:41 »
Don't forget the brakes and tyres will also need bedding in.
Abarth 595 Turismo + Classic Mini + Triumph Street Triple RS
Did have 3door DBP GTI PP
Offline remlapeel
« Reply #13 on: 14 February 2016, 21:42 »
Smash them to!
Offline GTI_Ant
« Reply #14 on: 14 February 2016, 21:44 »
Varied revs and up to 3/4 throttle for first few hundred miles, the occasional full throttle burst up to 4500 won't do any harm.  I takes about 20 hours of varied driving to do the initial bed in.  Thereafter, further settling in takes place over about 10K in my experience.
I always start with the oil temperature showing.  You can't go by the water temp gauge as the coolant heats up very quickly on these motors.
GTi Clubsport DCC winter pack rear camera
Previous:
7.5R 3dr DSG DPB Prets Dynaudio
MK7 GTI PP Tungsten Silver Manual Nav Dynaudio Winter Pack Park Assist
Offline Booth11
« Reply #15 on: 14 February 2016, 21:47 »
In my manual, page 339 and 340 suggest how the engine should be run in.
Personally I wud adhere to this, but etto.
Christ, how big is the manual?
It's an epic read :laugh:
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline Fabio Bignose
« Reply #16 on: 14 February 2016, 21:56 »
He!He!
Or you can just use the Index... ( had to put the manual down to post this )
Mk7.5 GTD. DCC, Keyless, Dynaudio, Tech pack, Alarm, Isaac Blue
Mk7 GTD. Xenons, 18", Climate Control, Keyless, Alarm, ( all optional in Ireland...! ) Dynaudio, DCC,
CSG.
Mk6 GTD. Alarm, CSG.
Offline corgi
« Reply #17 on: 16 February 2016, 11:33 »
And you'd trust them to give you the correct answer?  :rolleyes:
Corgi
Offline phazer
« Reply #18 on: 16 February 2016, 17:47 »
I'm of the don't baby it persuasion when it comes to 'run in'. However, the drive train is bench run in these days, but the tyres brakes and suspension components are not. You should allow 250-500 miles for these to bed in before truly caning the arse off the car!
Offline monkeyhanger
« Reply #19 on: 16 February 2016, 19:52 »
There's no bench running in, that would be a massively time consuming and costly operation. They are built to very fine  tolerances these days, and they get a quick turn-over check to ensure everything was put together properly - that's all they need.
