Author Topic: Airbag light! HELP  (Read 2225 times)
Offline Jimmer13
Airbag light! HELP
« on: 14 February 2016, 00:34 »
Help! I have a 2000 1.9 tdi, perfect running order, in great condition! But I have the airbag light on and it won't go out.
On the diagnostic it reads "Code 00588 - airbag squib circuit, driver. Too high impedance. Permanent"
I have changed the squib twice, I have changed the wiring inside steering wheel, cleaned all yellow connections. Even taken seat out and removed the connection underneath and soldered together.
What else can I do, if I can't get the light out it will fail the MOT, the car is far to good to give up on.
Many thanks
Jim
Offline baker1983
Re: Airbag light! HELP
« Reply #1 on: 14 February 2016, 22:28 »
If you have changed the squib(spiral cassette)then potentially could be the actual drivers airbag.
I shouldn't tell you this but you can break the airbag led/bulb and all an mot tester can do is advise srs bulb doesn't illuminate.
