Author Topic: Trip computer going nuts! Help!  (Read 4836 times)
Offline BlinGTIes
« on: 12 February 2016, 21:20 »
Hi fellow GTI'ers,
Need some help. Was driving the GTI on local roads tonight and noticed the mpg on the trip computer going mental. Kept changing from 200 mpg down to zero, kept doing it over and over. Normally it settles down after a few minutes driving but it just kept winding down from 200 mpgs.
Has anyone else experienced this? Wondering if it's software or a mechanical fault i.e. Sensor.
Any advice would be mucho appreciated!
Offline SRGTD
Re: Trip computer going nuts! Help!
« Reply #1 on: 12 February 2016, 21:37 »
There are 2 settings for mpg in the computer in my car; instant and accumulated for the distance driven. If you've got it set on instant, then it does continually change - the degree of change depending on how hard you're accelerating or whether you're decelerating.
Do all of the other functions in the computer work OK?
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Offline BlinGTIes
« Reply #2 on: 12 February 2016, 21:44 »
Yeah, it's the instant reading that's going nuts. Before it would fluctuate around 20-40 mpg and then setting s around 30 once I've been driving for more than 5 mins. Now it like starts at 200 mpgs and then counts down to 0 over and over.
Offline Rhyso
« Reply #3 on: 12 February 2016, 22:14 »
You need to switch it off 'instantaneous mpg'
Sounds like you've knocked the switch from average to instantaneous  :wink:
Offline BlinGTIes
« Reply #4 on: 12 February 2016, 22:29 »
I know when you press the ok button it cycles between to two, I saying even for the instantaneous reading it's going mental. Usually, it takes a few mins before stabilising, usually around 28 mpgs. Now it starts at 200 mpgs and drops to zero and repeats over and over. Just looks like it's on the fritz, will have to take it into VW to have a look. Luckily still under warranty :)
Offline BlinGTIes
« Reply #5 on: 12 February 2016, 22:59 »
Or is there a third mpg reading that I don't know about Rhyso?
Offline bgbazz
  • If it aint broke...I can fix it!
« Reply #6 on: 13 February 2016, 06:58 »
Have you tried a complete 'reset'...everything back to zero? Mine has a specific button for that function,
Or unhooking the battery for 20 - 30 mins?
Mk4 Golf TDI Estate 4Motion, remapped 1.9. Sweet runner = keeper. She is the 66th vehicle I've owned and hopefully, the last.
Offline Rhyso
« Reply #7 on: 13 February 2016, 07:52 »
What happens when you touch the accelerator when viewing this reading?? Different positions will give different readings  :smiley:
Within each trip computer (you have 2) you should have
Distance
Time
Average speed
Average mpg
Instantaneous mpg
Cycle through the menu  :wink:
Offline BlinGTIes
« Reply #8 on: 13 February 2016, 11:23 »
Distance
Time
Average speed
Average mpg
Instantaneous mpg
It's def the instantaneous that's on the fritz, all other readings look fine. Will check if the way I drive has any influence on the reading. I think it's prob a sensor of something coz I'm not driving any differently to before and it never did this!
