Author Topic: Bluetooth for RNS510  (Read 4263 times)
Offline T_J_G
« on: 29 January 2016, 19:11 »
Hello,
Been a while since I last logged on here.
I will be picking up a Mk6 GT TDI at the weekend and it's fitted with a RNS510 and bluetooth prep, however doesn't work with the iPhone.
I'd like to have t fintioning with my iPhone so was wondering if it's possible to purchase a new BT module and update the RNS using VAGCOM? I've looked into the Fiscon but £300 seems a bit steep.
Can anyone shed anymore light on this?
Thanks
Tim
Offline T_J_G
Re: Bluetooth for RNS510
« Reply #1 on: 07 February 2016, 07:16 »
Well my research suggest that buying a later bluetooth module and swapping out the old one will have the desired effect, and will only need coding if I want to use voice controls.
Offline wrighty57
« Reply #2 on: 09 February 2016, 12:48 »
hi
I bought a bluetooth mod for my gti mk 6 as the original didn't work with iphone 6 &,dealers wanted stupid money,bought 1 off eBay easy to install under front seat just plugged it in and it worked no coding needed think i paid £85 rather
Offline gaurav_aidasani
« Reply #3 on: 10 February 2016, 10:15 »
I also have an RNS 510 and thinking of adding Bluetooth. Just don't know if I already have Mic and whether it's Bluetooth prepped. If I press the phone button on RNS or mic button on steering wheel the music is muted.
Any thoughts?
Maybe I need to check under driver seat to see if there's an empty module ?
« Last Edit: 10 February 2016, 10:18 by gaurav_aidasani »
Offline dubber36
« Reply #4 on: 10 February 2016, 10:39 »
Scroll through the DIS using the <> buttons on the right of the steering wheel. If Bluetooth is fitted, there will be a Bluetooth menu in there. The fact that pressing the phone buttons on the radio and steering wheel mutes the radio, suggests you don't have it.
Offline Db4193
« Reply #5 on: 10 February 2016, 21:18 »
hi
Do you know the model number of the unit you got? Does music play through Bluetooth too?
Offline T_J_G
« Reply #6 on: 11 February 2016, 15:58 »
Also do you have a shark fin aerial?
£85 seems a good price and would snap one up at that price to enable the functionality. Seems likeI just need to buy the module itself.
Also looking into what firmware I can put on the RNS510 and what maps etc, won't let me go into secret menu to see what version it is.
Offline T_J_G
« Reply #7 on: 11 February 2016, 16:22 »
Appears the unit I'm after is 5K0 035 730B - £150 on eBay!
