Author Topic: Help engine light on and fault codes???  (Read 3234 times)
Offline Bobbydazzlerr
« on: 24 January 2016, 17:09 »
My friend has just changed my cam chain tensioner as its a 2010 after doing it went for a drive car felt like it was being held back the fault codes are p0016 camshaft crankshaft position and 00022 any help would be great car is taking abit to start 😡
Full blueflame 3inch turbo back system sports cat, pipercross panel filter, revo stage 2 remap 290 bhp 350 lbft, neuspeed short shift, heko wind deflectors, forge blow off valve.
Offline itavaltalainen
Re: Help engine light on and fault codes???
« Reply #1 on: 24 January 2016, 17:11 »
timing off???
« Reply #2 on: 24 January 2016, 17:23 »
We rip tied the chain together and replaced it with the latest tensioner so dont no how it could be? And it still runs?
« Reply #3 on: 24 January 2016, 17:48 »
Could it be the vvti timing out? How do you time it up? Thanks for ure help
« Reply #4 on: 24 January 2016, 17:50 »
Was the old chain lengthened before you replaced it?
Possible it's out by a little because of that now.......
There is a quite set procedure for replacement, did you have that to hand or did you try the 'old fashioned' way you'd use on a 90s 8v engine without vvt and a cam belt?
« Reply #5 on: 24 January 2016, 17:56 »
We have only replaced the tensioner as the old one is known to fail?
