Author Topic: Nuespeed fan switch wiring question  (Read 1608 times)
Offline ian007miles
« on: 23 January 2016, 14:15 »
Hi every one I'm fitting a nuespeed 85c 93c 3 pole fan switch and the wiring diagram says solid red is +, red with black stripe is high speed and the red with white line is low speed. BUT the problem I have is I have a red with yellow line instead of the red with black line but I don't want to just assume it's yellow instead of black can any one help thanx Ian
« Last Edit: 24 January 2016, 17:53 by ian007miles »
Agu|k03s|forge 007 dv|forge boost pipes|forge water pipes|forge tip|forge kona cold air intake|milltex 3" down pipe sports cat|milltek cat back exhaust|r-tech custom remap 238bhp and 235 torque
