Author Topic: Correct front bumper alignment?  (Read 9496 times)
Offline Peeair
« on: 20 January 2016, 17:00 »
Hi Everyone,
I had a bumper respray just before Christmas, picked the car up and didn't think much more of it.
Then tonight when having a look around the front I spotted a gap between the front grille and the bumper.
I can't remember if that's how it came from the factory or if it has just been re-fitted badly.
Would you guys be able to have a look at yours to put my mind at rest?
Thanks in advance!
Golf GTI MK 7, Manual, 3 Door, Pure White, Performance Pack, ACC, Keyless, Dynaudio
Offline p3asa
Re: Correct front bumper alignment?
« Reply #1 on: 20 January 2016, 17:42 »
What's the other side of the grille like, is it the same?
That's definitely not fitted right. The grille should be on top of the bumper not behind it.
Offline kalimon
  • My other car's a van
« Reply #2 on: 20 January 2016, 17:50 »
That looks a right shambles!
Anyone can see that's not been fitted correctly.
5 DR Mk 7 GTI PP
Offline Peeair
« Reply #3 on: 20 January 2016, 17:52 »
It's the same both sides.
I think the the grille is sitting above the bumper rather than behind it.
Either way it makes me wonder how they could get it wrong? Surely its just a case of putting the bumper/grille in place and tightening the screws?
Offline p3asa
« Reply #4 on: 20 January 2016, 18:07 »
I recently took my grille off as I was planning on doing something with the badge but changed my mind but its pretty straight forward. I'd have a go myself if I was you. It just looks like its not been fitted correctly
I can't get photobucket to take my upload but here's a picture of mine
https://www.dropbox.com/s/at4c84epss4aatv/IMG_1861.JPG?dl=0
Even the gap between your grille and light looks abnormally large!! It could be because the grille is sitting on the bumper though.
« Last Edit: 20 January 2016, 18:09 by p3asa »
Offline JoeGTI
« Reply #5 on: 20 January 2016, 21:30 »
It's definitely not right but it could be just not clipped in correctly. It's really easy to remove the grill though if you want to try re-seating it yourself. I took mine off the GTI to fit the red GTI badge.
Open the bonnet and there's 2-3 torx screws. Remove those and then just give it a gentle tug, the whole grill will pop out easy. I think there's a few tabs/clips along the bottom, maybe they're just not seated into the bumper properly.
Offline Peeair
« Reply #6 on: 20 January 2016, 21:36 »
Thanks for the input, I shall take a look tomorrow.
If I can't see anything obviously out of place I'll be going back to VW on Friday.
Offline Sootchucker
« Reply #7 on: 21 January 2016, 11:56 »
For reference, here's how mine looks if it helps ?
Offline dubber36
« Reply #8 on: 21 January 2016, 12:04 »
There looks to be a bit more to it than just refitting the grille. It looks like the gap between the grille and headlight will still be too wide.
Offline jv
  • Administrator
« Reply #9 on: 21 January 2016, 13:45 »
Yeah, that's miles out!
Buy site stuff!
GolfGTI.co.uk - merchandise
Support the forum charity!
