Author Topic: Washer jets not working :-(  (Read 4494 times)
Offline maxmc2
« on: 15 January 2016, 14:38 »
Me again.
Latest on the list to go are the washer jets.
Initially i suspected the pump so being on a few pound i changed it, guess what, doesn't work.
Ive checked the fuse but its on the same one as the wipers which work so im a bit stuck.
What should i check next and how?
TIA
Offline itavaltalainen
Re: Washer jets not working :-(
« Reply #1 on: 15 January 2016, 18:17 »
Can you hear the pump?
Do only front not work or back as well?
Do you have a multimeter? If not buy one.
Offline AntGTD
« Reply #2 on: 15 January 2016, 18:21 »
Check the fuse as it may have blown
2016 Mk7 Golf GTD 180(ish) Reflex Silver with loads of stuff
Offline danmusic24
« Reply #3 on: 15 January 2016, 20:09 »
ANY WATER IN THE BOTTLE :laugh:
Offline maxmc2
« Reply #4 on: 15 January 2016, 23:19 »
Yes water in bottle lol as trainer got soaked when changing, can't hear pump working at all, checked fuse and fine, does it have a relay at all?
« Reply #5 on: 16 January 2016, 00:14 »
Washer pump is switched from stalk.
See if you get voltage to pump (as suggested with a multimeter).
Offline maxmc2
« Reply #6 on: 16 January 2016, 00:46 »
Ok I'll try that first, many thanks
Offline jimmydub
« Reply #7 on: 16 January 2016, 11:47 »
its been pretty cold, they couldve of frozen  :laugh:
Offline maxmc2
« Reply #8 on: 16 January 2016, 11:52 »
Not frozen as pump works if I put a charge to it, problem is I'm not getting an voltage down the line, checked the fuse and all fine, is there a relay for this or could it be the stalk itself? Thanks
« Reply #9 on: 17 January 2016, 10:26 »
Check the stalk and it's wiring to the CE (connector H/H1). Wires from stalk to CE are green-red and green-black. From CE (plug C) it goes to pump with green-red and brown-blue. It switches polarity depending on whether you want to spray front or back.
See A2 resources CE2 diagram below (mind you wire colours are not 100% correct for the mk3 on there).
