Author Topic: Mk4 Golf Running Very Lumpy  (Read 4203 times)
Offline niliano
« on: 12 January 2016, 08:22 »
Hi Guys,
MK4 Golf 1.8T AGU engine Code
I have a issue and wanted to ask your opinions!
The other day I went out for a drive to Halfords to get a few bits to fix my door handle (was loose!) and the car to Halfords was running absolutely fine, didn't miss a beat accelerated and boosted exactly how it should be.
When I left Halfords and went up a ramp to a motorway and boosted the car all of a sudden shuddered and lost a lot of power.
Nursing the car which now sounds like a Subaru home I was barely able to get past 30 mph and going up a hill I was doing 20mph at 1mpg!
Checked the coil packs and cylinder 4 was the issue, As disconnecting the other 3 when engine was running made the engine shudder, Disconnect 4 and the car didn't change at all.
Put a new coilpack in and still the same outcome. moved coil packs around and again 4 was still the same.
Took the spark plug out of cylinder 4 and the tip was discoloured (almost white)
Today I have ordered 4 spark plugs (NGK ones) and 3 ignition coils.
If this doesn't work could anyone else shed light?
Do you think im on the right path to fixing this?
Ever since putting the spark plug from cylinder 4 to cylinder 3 the car isn't running as lumpy but still sounds like a Subaru!
Many thanks in advance
Offline barrym381
Re: Mk4 Golf Running Very Lumpy
« Reply #1 on: 12 January 2016, 12:32 »
I would be checking your ignition amp as coil packs very rarely fail on the agu  :smiley:
Offline niliano
« Reply #2 on: 12 January 2016, 12:53 »
forgive my stupidity
where would I find that?
Offline barrym381
« Reply #3 on: 12 January 2016, 12:58 »
have a read at this  :smiley:
http://www.golfgtiforum.co.uk/index.php?topic=206325.0
Offline niliano
« Reply #4 on: 12 January 2016, 13:01 »
cool thanks :) ill have a read!!!!
Offline niliano
« Reply #5 on: 12 January 2016, 13:02 »
where would it be? as I haven't got the standard air box anymore
Offline barrym381
« Reply #6 on: 12 January 2016, 13:05 »
mine is bolted to the bulkhead as my air box is gone too  :smiley:
Offline niliano
« Reply #7 on: 12 January 2016, 13:23 »
ok I don't recall seeing it but if what your saying then ill have a look :)
Offline niliano
« Reply #8 on: 12 January 2016, 13:29 »
would it be loose?
the car came with a air filter already fitted so I don't know where it would be haha
Offline barrym381
« Reply #9 on: 12 January 2016, 13:35 »
would it be loose?
I have seen them left loose in the past so have a good look about the airbox area  :smiley:
have a look at some google images so you know what your looking for  :smiley:
https://www.google.co.uk/search?q=mk4+golf+1.8t+ignition+amplifier&biw=1366&bih=599&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwix5K3VsaTKAhUCvxQKHadqDvQQsAQIHg#imgrc=5SSalIEPVGer2M%3A
