Author Topic: GTI MK6 Reverse lights too dim!  (Read 4897 times)
Offline BlinGTIes
« on: 11 January 2016, 22:19 »
Hi all,
New here so please be gentle.  Bought my first GTI last week and absolutely love it  :laugh:  Its a 2011 and has the LED tail lights.  The only problem is the reverse light is non existent!!! When reversing into my driveway I can't see a thing in the dark - thank god for parking sensors!
Has anyone else found this with their LED tail lights?  Is it possible to install a brighter bulb?  I might have to start turning my rear fog lights on to see where I'm going!
Cheers!
Offline The ANT
Re: GTI MK6 Reverse lights too dim!
« Reply #1 on: 12 January 2016, 06:33 »
Are they genuine vw as the real things are expensive so people fit ones the find off eBay, and are they as good as genuine ones?
Suffering from a severe and unforgiving case of GTItis
Offline mustard
  • Mk7 R
« Reply #2 on: 12 January 2016, 08:20 »
I have the genuine LED rears and the reversing lamp is not good, however I have also fitted the LED number plate lights and they give good illumination to the rear. I have tried to fit an LED bulb in the reversing light, but cannot find one that works.
You can also try the old trick I was told about years ago, of switching on the Fog light (and hazard lights) to give more light to the rear.
Offline dubber36
« Reply #3 on: 12 January 2016, 08:22 »
I use my hazard lights too.
Offline Db4193
« Reply #4 on: 12 January 2016, 10:07 »
I used led bulbs for reverse lights on my old car. They looked smart but for visibility were much worse than standard bulbs.
Offline BlinGTIes
« Reply #5 on: 12 January 2016, 20:37 »
Thanks for the responses guys.  Yes, I've resorted to using the rear fog lights to help me see.  Luckily its only on my drive way so won't look like a chief in public!
Offline Mattyj
« Reply #6 on: 30 April 2016, 15:41 »
Hazard lights again to reverse!? Do you only move every other second when you can see ;-p
