Author Topic: Updating maps on Discover Navigation Pro  (Read 2544 times)
Offline Toon
« on: 11 January 2016, 14:49 »
Can someone link me to the instructions on how to update the maps on Discover Pro please?
I saw a recent post with latest maps from November (I think) but not sure how to install them if I download the file.
Many thanks
Mk 7.5 Performance | DSG | 19" Brescia | Atlantic Blue | 5 door
Offline jv
  • Administrator
Buy site stuff!
GolfGTI.co.uk - merchandise
Support the forum charity!
Offline vidman2
Re: Updating maps on Discover Navigation Pro
« Reply #2 on: 11 January 2016, 20:27 »
After download - suggest the full map not the separate zips, takes no longer overall - and then unzip directly to the SD card not to a PC directory and copy across. You need a 32gb or larger formatted SD card
Once in the car the update takes about 40 minutes, do as a single update - keep the car turned on and do not interupt the update. Go for a long drive if you think your battery will not last, most will easily.
This way there are the fewist steps to get wrong and cause a c0ck up.
Worked for me and I was also unsure of the process
2015 R DSG. Limestone Grey, DCC, Winter Pack, Tech Pack, Reversing Camera    plus   2013 Mk7 GTi DSG - Performance, Navigation, Winter Pack, DCC, Park Assist,
Offline p3asa
« Reply #3 on: 12 January 2016, 17:09 »
...........keep the car turned on and do not interupt the update. Go for a long drive if you think your battery will not last, most will easily.
Just so the OP isn't spooked out, you don't have to do it in one go. My drive to work is about 10 minutes so it took me a couple of days to update the unit with no problems. You can happily stop and start.
