Author Topic: Bi-Xenon and HID Kit Installation  (Read 2969 times)
Offline h10_vwg
  • MK6 GTi and MK5 TDI
« on: 07 January 2016, 09:12 »
I have recently got myself aftermarket Bi-Xenons with the 15 SMD LED'S and  6K,35W HID kit
I have remoted the front bumper, grill, fog lamps etc..
when I have plugged in the new headlight with HID kit, the DRL's are not working?
I was under the impressions, this is plug and play.
Has anyone upgraded to the lights with HID's?
I was thinking it may be a Coding issue which can be enabled by a VAGCOM but advise was be much appreciated.
Offline mustard
  • Mk7 R
Re: Bi-Xenon and HID Kit Installation
« Reply #1 on: 07 January 2016, 18:48 »
Many of these kits only have the LEDs working as sidelights rather than as true DRLs. There is a way connecting the pins of the connector (4 and 10 I believe) to get the DRLs working.
Easy to check if this is the case, do they light up when you turn the sidelights on?
Offline h10_vwg
« Reply #2 on: 12 January 2016, 09:15 »
Yes, the DRL's work perfect when the side light is turned on!
I managed to pick up a set with the HID kit and it all seems to be working perfect!
The installation was pretty long but all worked well! :)
cheers
Offline chris1h
  • MK6 GTI BLACK 3 DOOR
« Reply #3 on: 12 January 2016, 20:33 »
cheers
get some pics up!  :laugh:
MK6 GTI - 2011 - PEARL BLACK - 3 DOOR  - 18" MONZA SHADOWS  -  RNS510/DAB  -  ACC  - SUNROOF  -  WINTER PACK  - DYNAUDIO  -  VIENNA LEATHER  - PARKING SENSORS  - BLUETOOTH
