Author Topic: Recommend repairer for French manufactured ABS Control Module?  (Read 4033 times)
Offline kelv
Hi Fellow GTI-ers
Happy New Year to you all.
I'm in need of someone who specialises in repairing ABS units (not just fit repair kits). The background:
So I've had an intermittent warning light come on every few weeks or so (the ABS+TC+handbrake trio). Finally managed to catch it while the error was still "live" in the system (it reset once you switched the ignition off) and it reported:
Quote
Address 03: ABS Brakes (-----)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 AE    HW: 1K0 907 379 AE
   Component: ESP MK60EC1   H35 0106
   Revision: 00H35001
   Coding: 163B600D092600FC681206E5901E0081B500
   Shop #: WSC 01316 785 00200
   VCID: 75CF0DCDDC5601967E-8021
2 Faults Found:
16352 - Control Module - Electrical Error
            014 - Defective - Intermittent
             Freeze Frame:
                    Fault Status: 00101110
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 14
                    Mileage: 87103 km
                    Time Indication: 0
             Freeze Frame:
                    Count: 0
                    Count: 32768
                    Count: 12800
                    Count: 96
                    Count: 51772
                    Count: 0
                    Count: 0
                    Count: 0
So! I took it down to my excellent local independent specialist: VW Audi in Bradford on Avon, and our course of action was to order a repair kit and replace the module.
Except that it turns out *my* GTI's control module isn't a BOSCH but a French manufacturer. It is part of the build of my car, but not the same component as the BOSCH ones. Independent garage was told by the Bath VW (where he got the repair kit from) that there is no repair kit for the French component and that the entire ABS (module + pump) will need to be replaced. So it turns out (also according to my independent) that only VW can do a full replacement as they won't release the codes to carry this out.
I'm facing a ~£1000 cost for VW to replace my ABS *unless* someone knows of anywhere that can service/repair these French ABS units. Does anyone know of anywhere please??? I'm going to leave it a month and then I'll book in with VW as I want it sorted out really, but it gives me some time to find an alternative plan.
Cheers!
Offline Rhyso
Re: Recommend repairer for French manufactured ABS Control Module?
« Reply #2 on: 06 January 2016, 16:47 »
VW fix the Bosch ones under a safety recall so I would argue that they should do the same for the ABS module you have
Offline kelv
« Reply #3 on: 06 January 2016, 22:52 »
Hmm do you have any further information on the recall? Cheers!
