Author Topic: app player on mk7 R  (Read 3577 times)
Offline wakey
app player on mk7 R
« on: 02 January 2016, 07:42 »
Hey
I understand that the option for the app player via the usb is a dealer option for £100.
Is this a software flash or can it be activated just by using vcds?
If it's a vcds activation then can someone please point me in the direction as I have the cable.
Many thanks in advance
Eta mine is a September 2015 with the standard small screen without factory navigation (although I've retrofitted the dealer gamin navigation.
« Last Edit: 02 January 2016, 07:45 by wakey »
MK7 Golf R. MK5 Golf Ed.30
Offline Wo-Wo
  • www.wo-wo.co.uk
Re: app player on mk7 R
« Reply #1 on: 02 January 2016, 17:41 »
Not 100% sure but don't you have to have pro nav for this option?
Offline p3asa
« Reply #2 on: 02 January 2016, 19:15 »
It doesn't have to be the Nav Pro, you can have the Car-Net App-Connect on the smaller unit as long as its MIB2.
@wakey There is loads of info online about dealers "being able" to activate it for you at a cost but I can only find one person having it done but after a search can't find it. If I recall correctly it was in the region of £200 to be activated.
Or according to this you could do it yourself!!
http://www.amazon.co.uk/Volkswagen-5G0-054-830-Activation/dp/B00Q6CH82E/ref=sr_1_1?ie=UTF8&qid=1442007116&sr=8-1&keywords=Activation+Document+for+Mirror+Link
Buy it from VW http://volkswagen-accessories.ie/mirrorlink_activating_document
The part no to ask your dealer about is 5G0054830
« Last Edit: 02 January 2016, 19:24 by p3asa »
Offline wakey
« Reply #3 on: 03 January 2016, 13:15 »
Wow - thank you for such a detailed reply. I really appreciate it
Thanks again :)
Offline fredgroves
« Reply #4 on: 04 January 2016, 13:06 »
Not quite sure what the "mirror link activation document" sold by Amazon does...
I would guess that somewhere in the menus there is an activation screen, into which you type in a one use code that then (using the GPRS datalink) connects to Volkswagen over the internet to validate and activate on your car...
A bit like using a prepaid card for your Xbox subscription...
On the other hand, i think it should be possible to hack the same functionality locally... if I had a MIB2 I'd give it a try, but i don't... MIB2 should be quite readily hackable I think you will find. MIB1 only isn't because its a pain to get the network connectivity up, MIB2 takes away those problems.
