Author Topic: Boot water leak  (Read 1936 times)
Offline darksideby182
Boot water leak
« on: 31 December 2015, 14:16 »
Hi hope somebody may help with water getting into my boot on a 5 door mk4 , found that the boot was getting condesated a lot recently.
I have taken the plastic trim covering the wiper motor and washer checked the washer hose which seems fine , but now with that plastic trim off a fair amount of water comes down one side on the boot when opened do you think the window seal may have gone? as looking around the rest on the boot i cant see where water would get in.
i have done a searchebut nothing seems to relate to the problem i have cheers for any help.
Offline itavaltalainen
Re: Boot water leak
« Reply #1 on: 31 December 2015, 17:21 »
Broken washer hose is common but if you checked that it's not (did you check at the top of the boot lid too?) that maybe rear light clusters.
Re: Boot water leak
« Reply #2 on: 31 December 2015, 18:04 »
The water runs out of the boot lid when you open it , its as if the water comes down the side of the boot window cant see it being anything to do with the lights.
cheers though
