Author Topic: Turbo upgrade  (Read 2953 times)
Offline Blad
Turbo upgrade
« on: 26 December 2015, 16:46 »
Hi need some advice my agu golf is in the middle of an engine rebuild ! New upgrade ko3s turbo new head water pump turbo house kit ect . It had a revo stage 1 map and was boosting at 16 psi before! Back on the road in 4 days! Will it run ok befor I can afford stage 2 map (will it need stage 2?)
Offline barrym381
Re: Turbo upgrade
« Reply #1 on: 26 December 2015, 20:30 »
it will blow up  :smiley:
Offline shaft69
Re: Turbo upgrade
« Reply #2 on: 29 December 2015, 01:54 »
Be ok that mate.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline Scott-R
  • GoT BoosT!
Re: Turbo upgrade
« Reply #3 on: 29 December 2015, 09:15 »
Is it your only car? Do you have to run it?
Golf GTI ... What else would you have?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Turbo upgrade
« Reply #4 on: 30 December 2015, 15:08 »
K03s will be fine on a K03 map
Offline niliano
Re: Turbo upgrade
« Reply #5 on: 06 January 2016, 11:06 »
im currently running a KO3's on a AGU block
I did have it mapped after the turbo swap as I heard so many different opinions I thought it would be best.
Personally I wouldn't risk it, but that's my opinion :)
