Author Topic: Mk2 golf GTI 2l bottom end conversation  (Read 6577 times)
Offline Kieranlaad1996
« on: 17 December 2015, 15:02 »
Hey guys just sign up but been roaming around for years as a guest yes I know a wee bit sneaky lol.
Anyway let get to it I want to do the 2l bottom end conversation on my mk2 golf 8v GTI
What I would like to know is what's involved I know quite a bit but I take it you use the original gearbox on the mk2 and of course the head as well lol but it's it an easy swap ect?
Another thing I'd like to know is will a mk3 golf Kent cam fit in my mk2 golf head?
Any help would be awesome guys looking at getting the parts before chirstmas hopefully and have it done asap :-)
Thanks in advance
Kieran
Offline Simeon
Re: Mk2 golf GTI 2l bottom end conversation
« Reply #1 on: 17 December 2015, 15:55 »
Easy job mate, loads of info on the web, just have a search on Google. eg: http://www.clubgti.com/showthread.php?248292-Mk2-Golf-2-0-8v-Conversion
You use everything already fitted to your engine pretty much, just might have to change/adapt the distributor depending on which 2litre bottom end you use.
Mk3 8v cam will be fine in mk2 head.
« Reply #2 on: 17 December 2015, 17:28 »
Thanks mate it's the AGG block
« Reply #3 on: 17 December 2015, 17:35 »
I'm using my gear box on the mk2 already so do I use the fly wheel off the mk2 or use the mk3 one?
« Reply #4 on: 17 December 2015, 17:36 »
And how do you modify the dizzy? Can't find anything on Google about the dizzy unless I'm tpying in the wrong thing
Offline gazareth
« Reply #5 on: 17 December 2015, 17:42 »
use the mk2 flywheel as it is lighter and give you a better throttle response :wink: with the dizzy you will need to swap the bottom gear of the agg one and fit it to the original dizzy. you will also need a dizzy spacer ring. also you need to use agg head gasket and timing belt/covers. that's about it really.
« Reply #6 on: 17 December 2015, 18:24 »
Thanks mate that's a big help take it you just use the mk2 golf head bolts? And can I make the spacer ring or do I need to buy one? And is it the same toque setting for the head bolts? Thanks in advance
Offline gazareth
« Reply #7 on: 17 December 2015, 18:37 »
yeah same head bolts and torque setting. I would just buy the spacer ring as they need to be very accurately made. I would also advise before fitting engine take the sump off and give it a good clean out along with the oil pick-up pipe/gauze.
« Reply #8 on: 17 December 2015, 19:00 »
Thanks mate where will I get the ring from and how much
Offline gazareth
« Reply #9 on: 17 December 2015, 22:09 »
if you go on google and type in "mk2 golf distributor spacer" then click on images and you will see it at top of page. there are about £20 but you could just buy a new dizzy for about £50. less hassle and you have a brand new part. if you choose to buy new then it needs to be a 2E dizzy and not an AGG dizzy as the agg spark set-up is not compatible with the mk2 golfs engine management.
