Author Topic: mk6 gti with DCC spring broken.  (Read 2894 times)
Offline Dipesh2031
  • Options bae?
« on: 17 December 2015, 11:46 »
hi,
My gti has broken a rear spring, I've been advised to put in 2 new rears, but I have the adaptive chassis control, wondering if normal gti suspension springs will fit or do I need the DCC springs, as I love the ride quality and dont want the ride to change!
Thanks
MK6 GTi - Black - DSG - 18' Monza shadow - Luxury Pack - Convenience pack - Park assist - Xenons - RNS510 - Adaptive chassis control - Dynaudio - Bluetooth - Reverse camera - front/rear sensors --mods-- Evoms Intake - Eurojet/stasis Turboback Catless 3" exhaust
Offline seabrook132
Re: mk6 gti with DCC spring broken.
« Reply #1 on: 18 December 2015, 18:01 »
They're different part numbers I believe so I'd be getting the DCC ones.
Do you need a part number? I've got ETKA so could look it up if you want
2011 GTI DSG 5dr, Tornado Red, 18" Monza Shadows, Heated Leather, RNS-510, MDI, Bilstein B16 PSS10 Coilovers, Ohlins DCC Cancellation Kit, Audi TT-RS Front Top Mounts, Whiteline 24mm Rear ARB, Michelin Pilot Sport 4, 034 Motorsports Street Density Engine and Gearbox Mounts, Audi R8 Red Coil Packs, NGK BKR7EIX, Millers 5W-40 Nanodrive
Offline itavaltalainen
« Reply #2 on: 18 December 2015, 21:48 »
DCC springs are a little shorter than standard, but a bit longer than sport suspension ones.
You'll need to fit DCC ones if they need replacing.
Offline Dipesh2031
  • Options bae?
« Reply #3 on: 27 December 2015, 03:08 »
turns out my mechanic put normal gti dsg springs, so now my rear sits higher, also have a horrible rattle coming from the front left, that spring might also be broken,( my car is from scotland, the suspension surface rust is alarming even at 50k)
might just buy VWR lowering springs! for that small 10-15mm drop and designed for DCC suspension. hopefully wont destroy ride quality
