Author Topic: Help with immo  (Read 2389 times)
Offline groggs
Help with immo
« on: 15 December 2015, 14:27 »
Hi
Try to make this short, my golf 2.0 gti 8v, starts up and runs for about half an hour then just cuts out.
I plugged in my VCDS,12.12 full version,and it came up with 2 faults  17978 and 16706.
The first code is immo, and the second one is engine speed sensor. I have had the car about 3 years and have only one key and it is not a fob key . this problem started about a month ago,any ideas on what i can try to solve this problem
Offline topher
  • Administrator
  • fully functioning
Re: Help with immo
« Reply #1 on: 15 December 2015, 17:06 »
Replace your crank sensor (engine speed sensor). A crank sensor that is failing will become more problematic when the engine is hot. If it was an immo fault the car would cut out when you first start it. Once the engine is running the immobiliser doesn't do anything, you can even take the clocks/immo out of the car with it running and it will continue to run.
Offline itavaltalainen
Re: Help with immo
« Reply #2 on: 15 December 2015, 23:12 »
And throw away that cracked VCDS 12.12 knock off China piece a sssss.
Offline groggs
Re: Help with immo
« Reply #3 on: 16 December 2015, 02:19 »
its not a cracked version from China its a full version with Ross Tech interface and serial code.
Re: Help with immo
« Reply #4 on: 16 December 2015, 17:47 »
Ok, then update it :D
Offline Rhyso
Re: Help with immo
« Reply #5 on: 16 December 2015, 21:55 »
This!
Its version 15.7 or something like that now
