Author Topic: torque settings  (Read 3077 times)
Offline Glowstone
torque settings
« on: 10 December 2015, 19:24 »
Hi all,
can anyone point me to a torque settings list please..I want to fit a new coolant flange to a 1.8t AUM and would like to nip it up properly.
kind regards
Martyn
Offline Mr_Orange
Re: torque settings
« Reply #1 on: 11 December 2015, 16:51 »
Don't know torque setting, but recommend a very light greasing of the o-ring to ensure a good seal ;-)
Build thread clicky
Offline itavaltalainen
Re: torque settings
« Reply #2 on: 11 December 2015, 17:48 »
Usually 20Nm for M7 bolts, bit more than half for M6 but mk4 should be M7.
Offline gazareth
Re: torque settings
« Reply #3 on: 13 December 2015, 00:37 »
I would stick some spring washers on the bolts and tighten them up with a screwdriver type tool. a smear of sealant and a new o ring and it should be sound.
Offline Glowstone
Re: torque settings
« Reply #4 on: 13 December 2015, 17:59 »
Many thanks for the replies all.
I nipped up the bolts hand tight after using RTV silicone then tightened harder an hour later.
here is the old flange and the block.
What I noticed, is that the coolant went down quite alot after running it, I am hoping its just bleeding itself of air and dropping as a result. The header hissed when I opened it so theres clearly pressure in the system.
Re: torque settings
« Reply #5 on: 13 December 2015, 18:50 »
The way that block looks you wouldn't have needed any additional sealant me thinks >D
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: torque settings
« Reply #6 on: 13 December 2015, 18:52 »
Now that's proper clean...
Offline Glowstone
Re: torque settings
« Reply #7 on: 13 December 2015, 19:53 »
I spoke to one of the mechanics next door who replaced 2 of these in the space of around 6 months and suggested a little RTV to be sure.
I think its a poor design really, surely a stainless flange would have been better? Even TPS have these flying off the shelf which I would have thought VW would have re-issued a more sturdy design?
Oh well, its in the hands of the gods as to if it holds out
 :smiley:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: torque settings
« Reply #8 on: 13 December 2015, 21:55 »
It's better for VWs profit margins if they can keep selling crap versions rather than selling one good version
