Author Topic: erratic idle and hissing sound on engine shut off  (Read 3945 times)
Offline seiko
« on: 08 December 2015, 15:00 »
Hi hoping some one can help me with a fault on my 2007 ed 30, noticed a slight miss on tick over when I stop at junctions and lights, and a hissing sound on engine switch off,
Closer investigation I could see the pcv was sucking in air from a small factory hole on the saucer part, took it off and seams to work fine you can suck one way but not the other, ordered a new one and fitted it just to be on the safe side,
With the new one fitted the engine revs and hunts between 1000rpm and 1500rpm, it pulses continually, I have changed all the spark plugs and new air filter and cam follower and dv, notice if I open the oil filler cap slightly to cause a vacuum leak it ticks over normally, hope some one can help it is driving me crazy,
Codes from vcds
Friday, 30, October, 2015, 14:53:44:21178
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
www.Ross-Tech.com
VIN: WVWZZZ1KZ8W016680   License Plate: MARC ED 30
Mileage: 84980km-52804mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVWZZZ1KZ8W016680   Mileage: 84980km-52804miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine        Labels: 06F-907-115-AXX.lbl
   Part No SW: 1K0 907 115 T    HW: 8P0 907 115 B
   Component: 2.0l R4/4V TFSI     0010
   Revision: 5BH16---    Serial number: VWX7Z0G43NE91R
   Coding: 0403000318070060
   Shop #: WSC 79925 024 394855
   VCID: 3778A67A461F3E86AC-8062
1 Fault Found:
004243 - Bank 1; Fuel Measuring System 2
               P1093 - 008 - Malfunction - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 2
                    Fault Frequency: 5
                    Reset counter: 255
                    Mileage: 81519 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 08:59:30
             Freeze Frame:
                    RPM: 1636 /min
                    Load: 17.6 %
                    Speed: 29.0 km/h
                    Temperature: 27.0°C
                    Temperature: 9.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 14.605 V
Readiness: 0000 0000
Offline seiko
Re: erratic idle and hissing sound on engine shut off
« Reply #1 on: 10 December 2015, 14:29 »
sorted this problem if any one has the same fault, turns out the pcv the vw dealer gave me was 06F129101P, if you intend to use this revision you wil need the rear pvc pipe with the check valve in, i returned it and for the 06F129101R straight swap works fine,  :smiley:
Offline wakey
« Reply #2 on: 20 December 2015, 09:24 »
The big clue was your car running normally with the oil cap off - it should run rough as hell
The engine struggles to idle due to too much crank case oil pressure. It can also force oil through ringlands, blow turbo seals etc etc.
Sounds like you got it sorted in time
MK7 Golf R. MK5 Golf Ed.30
Offline Bifferman
« Reply #3 on: 23 December 2015, 22:49 »
Glad you fixed it though  8) Merry Christmas
My Red MK5 "Terry" is a work in progress.
But Red is the only colour worth having. I did have a Black MK1, what was I thinking!
