Author Topic: missfire  (Read 2124 times)
Offline scottkayla
missfire
« on: 07 December 2015, 18:21 »
Hi ive a mk 4 golf that vag com saying missfire in cylinder 1 and 4 how can u tell what cylinder is what
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: missfire
« Reply #1 on: 08 December 2015, 17:36 »
cylinder one is nearest the drivers side as you look in the engine bay (cam belt end)
1 2 3 4
Offline Dalo Harkin
Re: missfire
« Reply #2 on: 09 December 2015, 17:08 »
Its probably one of the coil packs, check them by unplugging the wiring harness one at a time when the engine is running. When you remove one you should hear the engine noise change, if it doesn't you've found the broken one
Offline Nino
  • Insta - F6UGA
Re: missfire
« Reply #3 on: 28 December 2015, 20:05 »
Its also worth calling VW. The 1.8t's had a recall to replace all the coil packs. You might be lucky and not have had them done yet :)
Current - MK6 GTi Edition 35
