Author Topic: Flood water  (Read 5720 times)
Offline robtt
  • Golf Gti pp dsg
Flood water
« on: 05 December 2015, 20:14 »
Do not intend to try, but if you have to, what depth can you take a Gti through standing/flood water ? I imagine about four inches safely ? We are missing the big deluge where we live in North Yorkhire ,thankfully.But feel so sorry for those  affected  further North and west of here.
« Last Edit: 05 December 2015, 20:17 by robtt »
Offline p3asa
Re: Flood water
« Reply #1 on: 05 December 2015, 21:35 »
I took the GTD through a massive puddle today. Easily up to the sill.
I was always told, high revs and go slow.
Offline GeoBog
Re: Flood water
« Reply #2 on: 05 December 2015, 23:37 »
In theory any water up to the sills should be ok as the lower connectors/sensors are AMP type (waterproof). Most important when you do it is what p3asa said plus never stop the car and more important never stop the engine.
2020 VW T-Cross SEL
2020 Renault Megane RS Trophy 300
2012 Fiat 500 Twinair
2007 Renault Megane 2
The two most important days in your life are the day you are born and the day you find out why.
Offline remlapeel
Re: Flood water
« Reply #3 on: 06 December 2015, 11:52 »
16ft 8"
Much easier to drive down the river in my R.... 4WD and all that 😜
2015 MK7 Golf R 3 door, DSG, lapiz blue, 19" wheels, winter pack, keyless entry, dynaudio and high beam assist.
Offline pgibson007
Re: Flood water
« Reply #4 on: 06 December 2015, 17:53 »
One bit of advice - turn off the radar / collision sensor at the front in case the water goes over it and it triggers the brakes in the middle of a flood.
2016 GTI DSG 3 Door.  Reflex Silver.
Offline Finglonga
Re: Flood water
« Reply #5 on: 06 December 2015, 20:00 »
It doesn't slam on the brakes, it will bong and flash up that the system us unavailable as the sensor is blocked just like when driving in heavy snow.
I would not risk going through anything deeper than the top of the sensor to be on the safe side. Important to know the depth of the water before attempting any flood.
The intake at the lower edge of the bonnet so quite high up compared to some other cars. Of course if it isn't factory spec then you obviously need to make sure you know your safe depth.
Offline dubber36
Re: Flood water
« Reply #6 on: 07 December 2015, 07:57 »
Is it really worth the risk? I'd go the long way round having got stuck in a ford many years ago in a Citroen ZX Volcane. It ingested enough water through the intake that it aqualocked and stalled. Luckily we were able to climb out through the windows and push it out. Took the spark plugs out and turned it over to remove most of the water, then coughed and spluttered our way home.
Offline Booth11
Re: Flood water
« Reply #7 on: 07 December 2015, 08:57 »
I'd also avoid if possible, but if you do have to go through water, check your foglights carefully afterwards. On my daily commute there's a spot that floods and used to have to negotiate a small ford, or very large puddle.  Ended up with both fogs half filled with water. Changed my route in the end and set off 15mins earlier to avoid since then.
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline Sokkia
Re: Flood water
« Reply #8 on: 07 December 2015, 09:52 »
I would avoid in my own car after being stuck on a mini roundabout some years ago in a company Ford Focus. Sat looking at it for 10 minutes as cars came through it in the opposite direction and no problems, didn't fully appreciate the roundabout was on a significant cross fall. The water on my side was twice the depth as the other side. To be fair got a good way through before the bow wave came back at me and ended up over the top of the bonnet. Car conked in water over the door sills and I paid some "local yooths" to push me out, to save opening the door. As I bailed out the footwells they sat watching me, eating a McDonalds I had paid for, waiting for others to do the same thing. I am sure it was them that flattened the "Danger Flood do Not Pass" sign"!!! Cue a very good mock up of a Ford Focus Dealer catalogue doing the rounds at work. Available in my local area with such extras as Distress Flares, Out board Motor and inflatable life raft. Oh How they laughed.  :sick:
Current - MkVii 5Dr GTI Carbon Grey Manual.
Previously at various times- MkiV 2002 V6 4Motion Manual Black, Pug 205 1989 1.6 GTi Red Manual, Escort RS Turbo, 2006 RX-8 blue, 2009 A5 Cab Auto.
Offline Organisys
  • Old and Slow...
Re: Flood water
« Reply #9 on: 07 December 2015, 12:56 »
Been deeper than sills in a Touran, but the lump is higher in the shell than a Golf, 'zorst was well and truly submerged.
If your car is worth $ don't do it.
