Author Topic: Aerial lead  (Read 3434 times)
Offline philstar
  • ...life is all about creating memories...
Aerial lead
« on: 05 December 2015, 17:30 »
Does anybody know what the thin black wire that runs alongside the aerial is for?
Is it simply an earth?
It's on a 16V 1988 by the way.
« Last Edit: 05 December 2015, 17:47 by philstar »
1988 Atlas Grey VW Golf Mk2 16V GTi [F748 FGT]
Rebuilt: fuel pump housing | suspension | gear linkage | aluminium radiator
Offline h8v
Re: Aerial lead
« Reply #1 on: 05 December 2015, 20:46 »
It's the +12 volt supply to the amplifier mounted in the base of the roof aerial.
Connect it to the (probably blue) amplifier switch-on lead if your radio has one, or just to a circuit which is live when the ignition is on, such as cigarette lighter.
You should find the radio reception is a lot better with it connected.  If not, perhaps the aerial amplifier doesn't work!
Offline SimonG
Re: Aerial lead
« Reply #2 on: 05 December 2015, 21:07 »
As above, it's the 12v feed to the amp. If the reception doesn't change with the lead properly connected then the amp could've died, not uncommon.
  Mk3 Anniversary GTI 16V, Mk2 GTI
Offline philstar
Re: Aerial lead
« Reply #3 on: 05 December 2015, 22:18 »
Magic cheers guys!
