Author Topic: agu miles to empty  (Read 2566 times)
Offline markgti1.8t
agu miles to empty
« on: 03 December 2015, 09:50 »
can agu golf get miles to empty programmed in to it thanks
AGU fk coilovers Powerflex top mounts full 3inch decat turbo back viper induction kit fmic vr6 clutch g60 flywheel catch can 007 forge dv Power flex wishbone bushes  Power flex dog mount under brace JOM  ADJUSTABLE Drop Links Walbro 255lph INLINE Fuel Pump wmi now fitted WAITING TO FIT VR6 MAF SAAB RED TOP INJECTORS STILL TO BUY K300 TURBO  CON RODS LSD
Offline barrym381
Re: agu miles to empty
« Reply #1 on: 03 December 2015, 12:34 »
adam from here done mine on my aum couldn't do my agu though  :smiley:
Offline itavaltalainen
« Reply #2 on: 03 December 2015, 15:05 »
Depends on the part number and manufacturer of the speedo.
If you take it out and take a photo of part number label that also has manufacturer mark on it I can tell you.
Can enable MTE for you if your cluster supports it.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #3 on: 03 December 2015, 18:44 »
Standard AGU clocks will be immo2 so no go for them mate
Offline Dela90
« Reply #4 on: 07 December 2015, 19:49 »
Am I right in thinking you can upgrade standard AGU clocks to Bora clocks? prob bit of a newbie question I know
« Reply #5 on: 07 December 2015, 20:28 »
Yes you can. Will obviously need recoding.
