Author Topic: My alarm keeps randomly going off  (Read 2688 times)
Offline Ozzie826
« on: 15 November 2015, 01:41 »
For the past few days my alarm just keeps going off i havent changed anything on the car so not sure why any ideas ?
Offline itavaltalainen
Re: My alarm keeps randomly going off
« Reply #1 on: 15 November 2015, 09:47 »
Investigate the fault codes.... each time alarm goes off it stores a freezeframe in the fault memory, this will tell you why it went off.
So ask someone with VCDS or VCP to check fault codes for you.
Offline th3_f15t
« Reply #2 on: 15 November 2015, 10:05 »
Also, check the battery condition as a faulty battery will cause the alarm to sound. Fairly common reason for the alarm to sound randomly.
Moving over to Flickr, sorry for the broken picture links!
Offline Ozzie826
« Reply #3 on: 15 November 2015, 10:40 »
Thanks for your responses ill check both solutions but i do have a feeling it might be the battery but i will check the codes 1st and see what the problem can be.
