Author Topic: Price for BCM module  (Read 3178 times)
Offline SunnyGTI
« on: 14 November 2015, 13:34 »
Hi guys
What is average price to get a BCM module supplied and fitted?
Need to fit this due to fitting LED rear lights...!
Offline itavaltalainen
Re: Price for BCM module
« Reply #1 on: 14 November 2015, 14:10 »
You should be able to get a second hand BCM for under 100£.
Fitting and coding will depend who does it but could be equally much at VW garage.
Offline SunnyGTI
« Reply #2 on: 14 November 2015, 16:29 »
Thanks!
Quoted £130 to get it supplied and fitted by someone local. Which is reasonable I guess then
Offline golfhappy
« Reply #3 on: 14 November 2015, 21:01 »
Thanks!
If you can't get one from a supplier on ebay, mine was £60 then that's a good price. One from VW £263.
Audi S1 gone, awaiting 1.5tsi r-line, pan roof, led lights front and rear, active dash, 18" jurva alloys and a dealer fitted Oettinger roof spoiler in tornado red.
Offline golfhappy
Offline Gaz-M
« Reply #5 on: 17 November 2015, 16:19 »
If your going to add LED reg lamps, bear that in mind. Different BCM required again for that!
Offline golfhappy
« Reply #6 on: 17 November 2015, 22:08 »
That latest module should have the software for his led number plate lights?
Offline SunnyGTI
« Reply #7 on: 17 November 2015, 22:35 »
Thanks guys
I only have rear led tail lights not number plate lights so hopefully the part the guy fits is ok...!
