Author Topic: Can one replace a CCZ engine with a CAW or BPU one.  (Read 3817 times)
Offline mueneni12
« on: 11 November 2015, 15:37 »
Hi Guys, Is it advisable to replace the CCZ engine with either a CAW or BPU? if I do, what else need to get changed?
Offline itavaltalainen
Re: Can one replace a CCZ engine with a CAW or BPU one.
« Reply #1 on: 11 November 2015, 17:47 »
Why would you?  :huh:
Offline mueneni12
« Reply #2 on: 11 November 2015, 20:41 »
Old engine damaged, so looing at options of fitting a used one.
« Reply #3 on: 11 November 2015, 22:11 »
Easiest to fit the same again, if you fit others then you will also need to replace ECU, most likely also wiring loom.
If you only change block like for like and leave old ECU in place it will just run (possibly will require teaching it injector values etc) but you won't need to reprogram immobiliser (already fairly tricky on a mk6 and highly likely means you will need to get new transponders for the keys too).
Out of interest what's gone on your CCZ?
