Author Topic: Can I fit brake disc that have a different stud pattern?  (Read 2526 times)
Offline Blazeman1995
So this might sound like a stupid question, however it is a question I would like an answer to. Basically the discs on my car are starting to wear a bit thin. But I would also like to fit rims that have a 5x120 stud pattern. So I was wondering whether it would be possible to fit discs that use this pattern or would I use an adapter on a new set of 5x100 stud pattern (stock discs) in order to fit them.
Offline itavaltalainen
Re: Can I fit brake disc that have a different stud pattern?
« Reply #1 on: 08 November 2015, 21:02 »
You'd also have to change the hub, though there are no 5x120 hubs for a mk3.... so fit original discs and then put adapters on.
« Reply #2 on: 08 November 2015, 21:07 »
Ah ok, I had suspected that but was a bit unsure. Thanks for clearing that up
Offline tweed
« Reply #3 on: 11 December 2015, 20:07 »
Bbs rc wheels?
