Author Topic: taking car to 270bhp  (Read 8730 times)
Offline dime3x
« on: 08 November 2015, 20:44 »
Hi guys, i have a mk4 gti , its 150 standard and I've had it mapped to around 190 according to longlife. I'm thinking about taking it up to around 270 as I've heard i can get the ko4 turbo which will allow me to do so? Anyway if not could you point me in the right direction as to what I need next to get more bhp out of my car please.
Thanks in advancee
Offline barrym381
Re: taking car to 270bhp
« Reply #1 on: 08 November 2015, 20:49 »
you can buy a hybrid turbo that will see close to these figures  :smiley:
http://www.beachbuggyturbo.co.uk/k300---k03s-hybrid-turbo-1-p.asp
« Last Edit: 08 November 2015, 20:58 by barrym381 »
Offline dime3x
« Reply #2 on: 08 November 2015, 21:41 »
i'm not sure what turbo i have at the moment it might just be ko3 ? what other upgrades would i have to make if i add the hybrid to my car?
Offline barrym381
« Reply #3 on: 08 November 2015, 22:13 »
what year is the car  :smiley:
Offline dime3x
« Reply #4 on: 08 November 2015, 23:18 »
its a Y reg 1.8T
Offline spudboy6
  • Just like a golf ......
« Reply #5 on: 08 November 2015, 23:20 »
Hybrid your need
Injectors
FMIC
4bar fpr
Decent exhaust 3" turbo back
Intake pipe
Fuel pump 4bar+
Decent air filter
Ko4 your need the above and
Exhaust manifold
Custom down pipe
Turbo oil and water lines
Probably missed a few bits but your better with a hybrid and pretty much over 300ft-lb you need to forge your internals
Offline dime3x
« Reply #6 on: 09 November 2015, 18:20 »
Thanks for the reply, I already have an aftermarket exhaust on her from longlife so should that be ok? It's going to be a while until I can afford to do it just getting some info beforehand
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #7 on: 11 November 2015, 21:14 »
You won't necessarily need a 4bar FPR, depends who will be mapping it
Offline dime3x
« Reply #8 on: 12 November 2015, 20:22 »
would it be worth upgrading the clutch and flywheel too ?
Offline dubber36
« Reply #9 on: 13 November 2015, 16:03 »
Hybrid your need
Injectors
FMIC
4bar fpr
Intake pipe
Fuel pump 4bar+
Decent air filter
Exhaust manifold
Custom down pipe
If a rebuild is necessary, would it not be better to start off with a BAM engine?
