Author Topic: Led rear lights vcds coding help needed??  (Read 10940 times)
Offline Bobbydazzlerr
« on: 21 October 2015, 17:30 »
I have fitted golf r led rear lights to my gti and it has brought the bulb light on and when start the car tells me all the bulbs are out on the back my friend has got a vcds that i can use but i am not sure how to get the light off do i have to change numbers? Any help would be great thanks
Full blueflame 3inch turbo back system sports cat, pipercross panel filter, revo stage 2 remap 290 bhp 350 lbft, neuspeed short shift, heko wind deflectors, forge blow off valve.
Offline jv
  • Administrator
Re: Led rear lights vcds coding help needed??
« Reply #1 on: 21 October 2015, 17:36 »
Search is your friend.
Buy site stuff!
GolfGTI.co.uk - merchandise
Support the forum charity!
« Reply #2 on: 21 October 2015, 19:59 »
You have lost me?
Offline golfhappy
« Reply #3 on: 22 October 2015, 01:23 »
Are all lights working properly since you put the rear LEDS in? if so and its throwing an error on the dash you may need to code it out with VCDS. Possibly byte 18 may need to be changed. If your friend does an auto scan and it's say 00 in byte 18. 00 hides the real factory set value for that byte.
Audi S1 gone, awaiting 1.5tsi r-line, pan roof, led lights front and rear, active dash, 18" jurva alloys and a dealer fitted Oettinger roof spoiler in tornado red.
« Reply #4 on: 22 October 2015, 10:26 »
Yes the lights work fine just need to change the code dont really no what i am doing here could ot be a few differnt codes or would i just have to change it too 18? Thanks for ure help
Offline Gaz-M
« Reply #5 on: 22 October 2015, 10:30 »
Search Google for a how to. If your friend is good with VCDS its very easy.
Offline jv
  • Administrator
« Reply #6 on: 22 October 2015, 10:39 »
You have lost me?
I typed 'rear lights vcds coding' in the search and found this:
http://www.golfgtiforum.co.uk/index.php?topic=264548
Buy site stuff!
