Author Topic: MK2 16V - Hydraulic clutch upgrade query  (Read 2146 times)
Offline laurenceyon
« on: 18 October 2015, 19:45 »
Hi All,
How do I upgrade the cable clutch on my MK2 16V KR to a hydraulic clutch? I want the same performance from my MK2 clutch as I get from my MK3 VR6 without having to replace the engine, etc - In order to achieve this result will I have to change the gearbox, pedal box, flywheel, etc?
I don't really want to change the gearbox/engine as she's a 16V, I want to keep her as original as possible.
Any help would be appreciated
Hi my name is Laurence, I'm very much like you. Only better.
Offline gazareth
Re: MK2 16V - Hydraulic clutch upgrade query
« Reply #1 on: 20 October 2015, 18:29 »
some of the mk4 golfs had an 020 type gearbox (same as mk2) with a hydro clutch set-up. you might be able to just change the end of the box over but I think the slave cylinder mounts to the actual gearbox casing so you would need to make a support for it.
