Author Topic: Coolant plastic y piece  (Read 2388 times)
Offline OSR
« on: 18 October 2015, 17:31 »
So I have the classic slow leaking of coolant from the y piece under the header tank. Been searching the Internet, eBay etc but nowhere seems to sell them? There's one on eBay at the moment off an Audi A3/s3 but it's used and I'd rather buy new if possible.
Any ideas on where to source one? If I can't find one I guess I'll just rig something up using generic hoses and connectors but would rather replac with like for like.
Cheers in advance, OSR.
Offline OSR
Re: Coolant plastic y piece
« Reply #1 on: 27 October 2015, 09:58 »
OK so I found that ECS Tuning make a nice shiny metal replacement, however nobody in the UK seem to stock it! :sad:
https://www.ecstuning.com/Volkswagen-Golf_IV--1.8T/Engine/Cooling/ES2795553/
I thought Awesome GTI might have, given they stock quite a few of the other ECS bits like the powergasket etc. I might try to contact them and see if they can get hold of one, failing that I guess I can just order one direct from the states. Anyone seen it stocked anywhere else?
My short term fix has been a bit of self amalgamating tape round where I think the pinhole leak is, won't know if its worked until I check the coolant levels again this weekend  :whistle:
« Last Edit: 28 October 2015, 09:01 by OSR »
Offline LR5V
« Reply #2 on: 27 October 2015, 23:07 »
$75!
Just stick with plastic
Check for a part number -google the number, you may find they are readily available on ebay
Failing that, order a new one from VW or TPS
Offline ian007miles
Agu|k03s|forge 007 dv|forge boost pipes|forge water pipes|forge tip|forge kona cold air intake|milltex 3" down pipe sports cat|milltek cat back exhaust|r-tech custom remap 238bhp and 235 torque
Offline OSR
« Reply #4 on: 03 November 2015, 13:42 »
Here u go mate http://www.psituning.com/product.php/24010/ecs_aluminum_split_pipe_coolant_fitting___1_8t
Fantastic! Thanks mate - ordered  :smiley:
Never heard of PSI Tuning before - look like they stock a wide range of stuff too, will bear them in mind when shopping for bits in the future.
