Author Topic: Aircon compressor :(  (Read 1810 times)
Offline ian007miles
« on: 18 October 2015, 11:39 »
Hi does any one no if u can rebuild/service the air con pump on a mk4 golf agu 18t as mine squeals like a b!tch wen u switch it on any help would be good thanx Ian
Agu|k03s|forge 007 dv|forge boost pipes|forge water pipes|forge tip|forge kona cold air intake|milltex 3" down pipe sports cat|milltek cat back exhaust|r-tech custom remap 238bhp and 235 torque
Offline steve.gti
Re: Aircon compressor :(
« Reply #1 on: 18 October 2015, 19:03 »
could it be the drive belt slipping/squealing
steve
Offline ian007miles
« Reply #2 on: 20 October 2015, 23:45 »
Na wen the air con is switched on the pulley spins but the clutch doesn't engage so it stops and starts spinning in the centre of u know wot I mean
Offline crazydog
« Reply #3 on: 07 November 2015, 17:09 »
hi maybe a bit late now answering i had this prob and the guys in the garage couldn't right it i pshed on myself to try and sort it and eventually found it was a bad fuse/connection new fuse clean contacts bingo all spinning working fine.the fuse/fuses are in a case on top of battery    cheers hope it works out
