Author Topic: Choke Pull Down Unit on a Pierburg 2E Carb?  (Read 3177 times)
Offline InsightMusic
« on: 15 October 2015, 12:35 »
Hey guys,
So my auto choke isn't kicking in on my Mk2 Golf GL 1.8 when I turn the ignition on, which means sitting there for 5 minutes or so with my foot down is a must, otherwise the car will simply stall.
I see a lot of threads and videos regarding the Pierburg 2E2 carb, but not so much on the 2E. Are there any main differences between the two? I know my carb doesn't have the choke pull down unit on the front or neither is their any vacuum reservoir connected to the carb in any way... As neither came fitted when I bought the car last year, are they essential for this carb or not needed?
I've been able to adjust the fast idle speed using the 3/4 point (I think it's called), but the automatic choke not kicking in is the real issue for me.
I've had the carb off completely, changed all the vacuum lines, cleaned it up, warmed up the wax stat (very stiff) contemplated throwing the whole thing in the bin and purchasing a weber, but decided to throw the pierburg back on and get to work.
So, any idea how to adjust the choke settings at all? Is it possible to buy a choke pull down unit to fit this carb, or will it simply not fit?
Here are some pics of the carb...
http://postimg.org/image/llfrccnhx/
http://postimg.org/image/9kywpd5h1/
http://postimg.org/image/px8yf3jsl/
http://postimg.org/image/3ml3f4mid/
Thanks for your help.
Offline Santiago
Re: Choke Pull Down Unit on a Pierburg 2E Carb?
« Reply #1 on: 17 October 2015, 11:17 »
That is a 2E2, it's just had a few bits removed at some stage (they all just say 2E on the casting). Only 2E2s have a waxstat, 2E3s as fitted to 1.3 engines don't.
Standard pull-down unit will fit, and you could try a simplified set-up with the top port of it blocked off to avoid the complications of the green ball, non-return valve and associated pipework.
« Reply #2 on: 20 October 2015, 15:15 »
Thanks for the reply mate, going to purchase the choke pull down unit off eBay now and see about fitting it back on to the crab.
