Author Topic: Will this wheel and tyre setup fit?  (Read 1402 times)
Offline xXRobbie98Xx
« on: 15 October 2015, 00:39 »
Alloys: 17x8
Tyres: 195/45R17
I'm expecting the tyres to be a but stretched. Will these wheels fit a mk4 gti?
« Last Edit: 15 October 2015, 01:06 by xXRobbie98Xx »
Offline itavaltalainen
Re: Will this wheel and tyre setup fit?
« Reply #1 on: 15 October 2015, 08:58 »
What's their offset?
195 tyre on 8" wide wheel? You gotta be kidding, this will look  :sick: and will ride like sh1te.... 225 minimum or better 235 width, though they probably don't make 235 tyre with a low enough aspect ratio to keep rolling diameter in spec for a mk4 (would need to bother a calculator to see if 235 30 17 would be OK).
Although you can change the WSZ in the dash to accommodate a limited change.
« Last Edit: 15 October 2015, 09:03 by itavaltalainen »
