Author Topic: Burnt out loom  (Read 9445 times)
Offline hardmonkeys
  • Moderator
Burnt out loom
« on: 12 October 2015, 10:13 »
Found out the problem with the Cab,
I like, an idiot, put then earth from the -ve battery lead to the starter motor
Instead of the gearbox bell housing, the starter was earth through the main loom...in effect melting then wires  :cry: :cry:
Options now, do I replace the loom, or repair it, rang around a few places today, see what options I have...
What do you recommend?
'05 VW Golf Mk V GT TDI Laser Blue
'98 VW Golf Mk IV GTi Black
'97 VW Golf Mk III GTi
'58 VW Golf Mk V GT Sport TDI Steel Grey
'10 Audi A4 B8 SE Multitronic
'00 VW Golf Mk III.V Cabrio
'12 Audi A5 S Line Black Edition
'0 VW Golf V6 4motion
MK3.5 Cabrio 2.0 8v Automatic to 2.0 16v Manual Conversion Project
http://www.golfgtiforum.co.uk/index.php?topic=272728.
www.dorsetautorestore.co.uk
Offline hardmonkeys
  • Moderator
Re: Burnt out loom
« Reply #1 on: 14 October 2015, 19:57 »
No-one?
Offline itavaltalainen
Re: Burnt out loom
« Reply #2 on: 14 October 2015, 20:17 »
Personally I'd replace the loom if you can find one.
If not you can put new wires in (get the correct thickness and colour codes) and crimp the ends, then complete test loom with multimeter, though this is quite laboursome and wires and crimp tool are not free either.
I would not just patch up the loom with short bits.... if it was just a single broken wire you could solder and shrink hose is as it won't have mechanical stress on it but since it's a fair few if not all I would not go down that road.
Offline hardmonkeys
  • Moderator
Re: Burnt out loom
« Reply #3 on: 15 October 2015, 10:15 »
Fair comment, thanks for replying. I'm on the lookout for a loom, if you know of one going, keep me in mind. Thanks again
Offline gasketface
Re: Burnt out loom
« Reply #4 on: 15 October 2015, 10:24 »
either way you go is a pain.
If it were me i would replace the loom but if you end up just splicing new wires in don't use crimp connectors as they will fail later at some point,better to solder, heatshrink and then insulate.
Offline hardmonkeys
  • Moderator
Re: Burnt out loom
« Reply #5 on: 15 October 2015, 16:53 »
Looks like the way to go then, will see what the auto electrician says tomorrow also, really didn't fancy taking the engine back out again, and stripping it down, still, if I want to do it properly and safely, itmneeds to be done
Re: Burnt out loom
« Reply #6 on: 15 October 2015, 21:06 »
When I said crimping I did not mean to fix existing wires and crimp a short bit to it but to remove the pins from the plugs, put in a new wire, end to end and crimp on a new pin on both ends and lock in plug again.
Offline hardmonkeys
  • Moderator
Re: Burnt out loom
« Reply #7 on: 16 October 2015, 03:19 »
That's a lot of work isn't it, it'll be quicker to replace the whole look, I've got a auto sparky coming at midday to have a ganders
Offline hardmonkeys
  • Moderator
Re: Burnt out loom
« Reply #8 on: 18 October 2015, 16:28 »
As predicted, he said it's better to find a new harness.
So that's the next job
Offline gazareth
Re: Burnt out loom
« Reply #9 on: 20 October 2015, 19:55 »
it doesn't look to bad to repair in the first pic but going by the second pic its toast. much better result to replace the whole thing.
