Author Topic: Trim Removal  (Read 5200 times)
Offline Juicetin
Trim Removal
« on: 11 October 2015, 18:08 »
Hi folks, determined to get to the bottom of a rattle on the dash, dealers have failed to find it after 4 visits. I think i have traced it to the carbon look strip above the glovebox, does anyone know how to remove it? On my mk5 it just simply unclipped but ive tried that and it wont budge. I have a trim removal tool.
Thanks.
Offline Fabio Bignose
Re: Trim Removal
« Reply #1 on: 11 October 2015, 20:12 »
evening,
whilst i dont know how to remove the trim, it might also be worth removing the glovebox and investigating if there's anything loose behind the dash.
Its in the manual how to do so.
Mk7.5 GTD. DCC, Keyless, Dynaudio, Tech pack, Alarm, Isaac Blue
Mk7 GTD. Xenons, 18", Climate Control, Keyless, Alarm, ( all optional in Ireland...! ) Dynaudio, DCC,
CSG.
Mk6 GTD. Alarm, CSG.
Offline remlapeel
Re: Trim Removal
« Reply #2 on: 11 October 2015, 21:33 »
Are you 100% sure it's the trim. I got the badly with both my mk7 and got it finally fixed Friday.
http://www.golfgtiforum.co.uk/index.php?topic=275795.0
2015 MK7 Golf R 3 door, DSG, lapiz blue, 19" wheels, winter pack, keyless entry, dynaudio and high beam assist.
Offline Juicetin
Re: Trim Removal
« Reply #3 on: 11 October 2015, 22:02 »
Cant be sure but it certainly sounds like its from the A pillar, air vent or trim, whats odd is that thay all feel solid with no obvious play in them. So yes i will check out the soundaktor too thanks.
Offline dv52
Re: Trim Removal
« Reply #4 on: 11 October 2015, 22:13 »
Thanks.
Juicetin: This is how VW says to remove the trim
No need to use the special VW trim tool - just get hold of a plastic tool that's used for IPAD/ mobile phone repairs
Don
« Last Edit: 12 October 2015, 01:48 by dv52 »
103TSI Highline ROW (my13)
Offline Juicetin
Re: Trim Removal
« Reply #5 on: 11 October 2015, 22:37 »
Thanks for that, it looks like the trim just unclips then. Blimey i tried that today and it wouldn't budge.
Offline dv52
Re: Trim Removal
« Reply #6 on: 12 October 2015, 01:44 »
Juicetin: OK, then that suggests that the rattle isn't coming from the trim.
As an alternative suggestion, why not remove the glove-box door (it's much easier to remove) and then search behind the trim panel for a loose component. Not sure if you have removed the glove box door before, but I wrote up a procedure (complete with pics) of how to do this in the link below (it's part of my instructions for altering the fuse function for the ciggy socket). Be careful to align the "slider" when re-installing
Don
http://www.vwwatercooled.com.au/forums/f197/permanent-12v-supply-power-socket-99113-post1077394.html#post1077394
« Last Edit: 12 October 2015, 01:47 by dv52 »
