Author Topic: Sound actuator removed (buzzing noise at 2500rpm)  (Read 3070 times)
Offline remlapeel
« on: 09 October 2015, 11:53 »
Had my windscreen replaced today and used the opportunity to try and stop that damn metallic ringing noise that sporadically starts and stops. I'm have had this issue with both my GTI and R and it's driving me insane.
First thing on note, it is categorically the sound actuator rattling. If you gently tap the metal which holds the device, you can hear a metallic tap.
I tried various pads and other things to bolster the device to no avail, it feels like the metal is to thin to support the device.
So, I have removed the sound actuator completely (weight saving bro!) and hey presto, completely buzz free!
2015 MK7 Golf R 3 door, DSG, lapiz blue, 19" wheels, winter pack, keyless entry, dynaudio and high beam assist.
Offline Gung-Ho
Re: Sound actuator removed (buzzing noise at 2500rpm)
« Reply #1 on: 09 October 2015, 13:05 »
You know what.... I'm getting the same intermittent "buzzing" noise from beneath my windscreen.  Never had this problem on my previous GTi... Is it easy to remove remlapeel?
Current Toys: Mk7 Golf R 5dr 'Manual', Lapiz Blue, 18" Cadiz Alloys... Caterham R300 Superlight... new Mazda MX5 2.0 SE-L (ND)
Offline remlapeel
« Reply #2 on: 09 October 2015, 14:02 »
Yeah extremely, that's part of the problem. It seems like it was an after thought and they haven't done it well.
There are 3 clips holding the surround in place which you can literally remove with your fingers. Followed by a single 10mm bolt and unveil the cable.
The guys at silver shield even gave me a cable tie to hold the wires tight so they didn't start to rattle!
Offline Gung-Ho
« Reply #3 on: 09 October 2015, 16:56 »
Thanks for that... I'll persevere with it for a little longer in the hope that the rattle settles down, but if not I shall be following in your footsteps.... Thanks for the info.
Offline dv52
« Reply #4 on: 11 October 2015, 22:10 »
oops
« Last Edit: 11 October 2015, 22:12 by dv52 »
103TSI Highline ROW (my13)
Offline Hawaii-Five-O
  • Are we nearly there yet?
« Reply #5 on: 13 October 2015, 12:05 »
Best thing I ever did to my GTI. Apart from finding the noise artificial, fake and tiresome it also caused the intermittent buzzing on acceleration. Once I disconnected it I felt like I had my car back :wink:
Current: BMW M140i / ZF8 / 5 DR
Past: MK7 GTI / DSG / WHITE / 5 DR
