Author Topic: 3000 rev stutter mk3 golf gti  (Read 3238 times)
Offline Paul.a.saurous
« on: 30 September 2015, 18:43 »
Hi guys this is the first time I've posted.
I own a mk3 golf gti 8v.  Recently it started juddering around 3000 revs. As far as I can tell the timing is right so first I replaced all filters followed by dizzy cap rotary arm hall sender spark plugs ht leads ignition coil. But still the problems there I've read loads of posts.
I figured I'd post this before admitting defeat and taking it to a garage. Any advice would be a great help thanks
Offline itavaltalainen
Re: 3000 rev stutter mk3 golf gti
« Reply #1 on: 30 September 2015, 19:16 »
Which engine?
« Reply #2 on: 30 September 2015, 20:28 »
Agg I think
VW BUSH
« Reply #3 on: 01 October 2015, 18:28 »
Does it stop at 3500 rpm, is it a proper hard judder/miss or more of a stutter and loss of power for 500rpm?
In order of cost only:
Search U281 buy one and scan it (could show up a bunch of faults, I bet you have a wheel sensor gone :grin:)
Search relays and change them.
Search crank position/angle sensor, change it
Search throttle body position/reset, Free but needs vagcom
« Reply #4 on: 01 October 2015, 21:35 »
Paul, where are you in the country?
If you're near me I can scan your car for faults and map throttle body after cleaning.
Offline lectrotek
« Reply #5 on: 04 October 2015, 22:33 »
I have exactly the same problem on my 16v   :sad:
Offline lectrotek
« Reply #6 on: 10 October 2015, 14:35 »
Thanks for this,
U281 shows no engine faults (only ALL the ABS wheel sensors!), so no joy there.
Crank sensor has been changed so ain't that.
That leaves throttle body position / relays.
Can anyone suggest anything else?
