Golf mk2
new brake piping
Topic: new brake piping (Read 2391 times)
Gaved
new brake piping
22 September 2015, 13:51 »
Hi All I hope your well
Its getting ever closer to the day i can actually drive my 89 mk2 gti! Its just finished having some welding done to the floor pan and sills and then i can start putting the interior back in then its off to an MOT!
But as per usual their is something else that needs doing and that is the brake pipes. The rear piping is ok (and is copper) so the front two and 2 main pipes from the reservoir that go along underneath the car need replacing. I was wondering how much of a job it is, shall i buy pre bent piping to save time etc or buy a big roll and bend into shape? i was thinking buying this
http://www.ebay.co.uk/itm/Vw-Golf-Mk2-Brake-Pipe-Diy-Repair-Kit-/231675035066?hash=item35f0e87dba
Would this be hopefully all i need to complete the set up?
Thanks
Gavin
Last Edit: 22 September 2015, 15:46 by Gaved
sparkplug
Here all the time
Re: new brake piping
22 September 2015, 16:59 »
i made up a full car set for a morris minor hotrod i built...about 10 years ago using exactly that set up
1986 GTI atlas grey
VW BUSH
Guest
22 September 2015, 18:41 »
Take your time and pull the copper out straight.
Bend it with a proper tool to avoid crimping it, I use some cord threaded through it to help.
Copper can get damaged from flick ups off the road and clumps with the jack
Gaved
25 September 2015, 14:54 »
thanks for both your inputs. Hopefully i get her back from the welders early next week so i can get started!
Golf mk2
new brake piping
