Author Topic: changing the auxiliary belt  (Read 1846 times)
Offline Scottymk4
« on: 21 September 2015, 15:17 »
I am getting a creaking noise when going from lock to lock and someone mentioned could be a worn aux belt...how hard is it to change this belt ?
« Last Edit: 21 September 2015, 15:33 by Scottymk4 »
Offline itavaltalainen
Re: changing the auxiliary belt
« Reply #1 on: 21 September 2015, 16:47 »
Dead esay, buy a Haynes if you're a novice at cars.
Offline Scottymk4
« Reply #2 on: 21 September 2015, 17:12 »
not a total novice but just never changed one of these before
Offline Dalo Harkin
« Reply #3 on: 21 September 2015, 20:39 »
Have you checked the power steering fluid? Never heard of a belt making a creak unless the pulleys shot
Offline Scottymk4
« Reply #4 on: 22 September 2015, 10:55 »
yeah the fluid is fine, got the rack changed a couple of months ago too. I didn't think it would be the belt to be honest although it does lok a bit worn so will change anyway...what else could it be a the creak is there when the car is  moving or not.
« Reply #5 on: 22 September 2015, 12:09 »
strut mounts, ball joints, track rod ends.... rubber bushes in wishbone.....
