Author Topic: Knocking when Turning and accelerating  (Read 3440 times)
Offline UnCl3RoRy
  • Silver - 2001 1.8T AUM
« on: 19 September 2015, 20:16 »
Ello guys.
Got a slight issue with a knocking sound when Turning and accelerating. It mainly does it when Turning right, so I assumed it was drivers side cv joint so I swapped it, but unfortunately it is still knocking. I don't have any noises Over bumps just sharp cornering.
Please can someone shed some light.
Thanks
If you no longer go for a gap that exists, you are no longer a racing driver - Ayrton Senna
Offline wakey
Re: Knocking when Turning and accelerating
« Reply #1 on: 17 January 2016, 08:29 »
Could be a number of things....steering arm and/or track rod end worn would be a first port of call. Then also top mounts as these allow movement when cornering.
MK7 Golf R. MK5 Golf Ed.30
Offline AntGTD
« Reply #2 on: 17 January 2016, 22:06 »
Thats a strange one as typically knocking on when turning would also happen over bumps etc.
I would consider - in no order:
Track rod ends
Ball joints
Drop links
Top mounts
Steering rack or rack mounts.
2016 Mk7 Golf GTD 180(ish) Reflex Silver with loads of stuff
