Author Topic: Urgent Help-Map SD card  (Read 1820 times)
Offline Optimus prime
« on: 15 September 2015, 10:54 »
I am wondering if anyone can help me with my map / nav issue.  VW are happy to replace the nav unit but they need the SD card with the maps on that apparently comes with every new car as the new unit will not be pre-loaded as it is done at PPI stage by the selling dealer.  Unfortunately this was the only thing that I didn't get from the previous owner!
Is it possible to borrow anyone's sd card if available?  It needs to be an SD card for discovery pro nav from new apparently.  Happy to cover special del each way for the SD card, as the car is going in this Saturday for the new unit.
Pls PM if you can assist
Thanks
Offline Jimble
  • Moderator
Re: Urgent Help-Map SD card
« Reply #1 on: 15 September 2015, 13:00 »
Pro navs do not come with the SD card, i've had 3 Golfs with pro nav and none have had a card with them, i pretty sure they're not required.
Offline mcmaddy
« Reply #2 on: 15 September 2015, 13:26 »
Yeah can confirm what Jimble said. Nav pro doesn't come with SD card and its rather worrying that your dealer thinks they do!!
« Reply #3 on: 15 September 2015, 13:47 »
Thanks to you both for confirmation just had this also confirmed by VW parts.  I guess the dealer is getting mixed up between the pro and media systems.
Offline GeoBog
« Reply #4 on: 15 September 2015, 21:03 »
Only Discovery Nav uses maps on SD as there is no internal storage capacity, unlike the Nav Pro which stores both the maps and software updates internally.
2020 VW T-Cross SEL
2020 Renault Megane RS Trophy 300
2012 Fiat 500 Twinair
2007 Renault Megane 2
The two most important days in your life are the day you are born and the day you find out why.
